# Z-axis belt calibration
**URL:** https://forum.sovol3d.com/t/z-axis-belt-calibration/9886
**Category:** Sovol SV08 MAX
**Created:** [April 15, 2026, 6:04am UTC](https://forum.sovol3d.com/t/z-axis-belt-calibration/9886 "2026-04-15T06:04:06Z")
**Posts on this page:** 5
**Page:** 1
<div class="post-metadata">
### Author: ![Mirko280379](https://avatars.discourse-cdn.com/v4/letter/m/eb8c5e/32.png) [@Mirko280379](https://forum.sovol3d.com/u/Mirko280379)
#### Post date: [April 15, 2026, 6:04am UTC](https://forum.sovol3d.com/t/z-axis-belt-calibration/9886/1 "2026-04-15T06:04:07Z")
</div>
I would like to know how often I calibrate the Z-axis belts for the Sovol SV08 Max. Is there a guide to performing the calibration effectively?
Best regards
MP
### Author: ![mich0111](https://yyz2.discourse-cdn.com/flex030/user_avatar/forum.sovol3d.com/mich0111/32/1176_2.png) [@mich0111](https://forum.sovol3d.com/u/mich0111)
#### Post date: [April 15, 2026, 7:48am UTC](https://forum.sovol3d.com/t/z-axis-belt-calibration/9886/2 "2026-04-15T07:48:34Z")
</div>
Hello @sovol3d
Maybe it’s for you.
Cheers
### Author: ![sovol3d](https://yyz2.discourse-cdn.com/flex030/user_avatar/forum.sovol3d.com/sovol3d/32/9_2.png) [@sovol3d](https://forum.sovol3d.com/u/sovol3d)
#### Post date: [April 16, 2026, 1:52am UTC](https://forum.sovol3d.com/t/z-axis-belt-calibration/9886/3 "2026-04-16T01:52:54Z")
</div>
Calibration is generally not required frequently. You only need to calibrate when you notice layer lines in the printed model or abnormalities in the Z-axis.
Make sure to measure a 150 mm length here to tension the belt, and you can judge the proper adjustment based on the frequency.
 ![f6ed0d4bc770aff6c328d4b8371bdbaa](https://canada1.discourse-cdn.com/flex030/uploads/sovolforum/original/2X/0/0f4c2cb5fff513b59a129891e35748d6391eb19c.jpeg)
You can refer to this: [SV08 Z axis belt replacement and adjustment tutorial | Sovol 3D Printer Wiki](https://wiki.sovol3d.com/en/SV08-Z-axis-belt-replacement-and-adjustment-tutorial)
### Author: ![Oddle](https://yyz2.discourse-cdn.com/flex030/user_avatar/forum.sovol3d.com/oddle/32/5935_2.png) [@Oddle](https://forum.sovol3d.com/u/Oddle)
#### Post date: [May 5, 2026, 3:39pm UTC](https://forum.sovol3d.com/t/z-axis-belt-calibration/9886/4 "2026-05-05T15:39:25Z")
</div>
@sovol3d
Do I need to remove the vertical structures just to tension the belt or can this procedure be run while the printer is assembled? Sorry for newb question just want to be sure. I love my MAX but I do have issues with the layer lines being uneven and poor looking.
Thanks in advance!
#### Post date: [May 5, 2026, 4:13pm UTC](https://forum.sovol3d.com/t/z-axis-belt-calibration/9886/5 "2026-05-05T16:13:44Z")
</div>
You should adjust the belts after the gantry is assembled, not before.
