What are these two fans used for on the enclosure? And why would I ever turn one on, but not the other?
So far I’ve printed PLA with the door open and ABS shut, but I assume there are some materials that need active ventilation?
I run both fans @ 30% (via macro in the machine pre-print G-code) to print PLA with the doors closed. Quieter and not in the way. They can be used to ventilate the cabinet when or after printing something like ABS or ASA that gives off noxious fumes. I made an adapter for the exhaust fan outlet to 4” flexible dryer vent and an insert for a nearby sliding window. Again, a macro in the post-print machine g-code. However, to run them continuously cools the chamber when relying on the bed plate alone for heat. If and when Sovol ever produces the promised chamber heater then they could be used on low for ventilation during printing of ABS, etc.
