# What firmware should I be using for the SV06 ACE PLUS and where should I be getting it?
**URL:** <https://forum.sovol3d.com/t/what-firmware-should-i-be-using-for-the-sv06-ace-plus-and-where-should-i-be-getting-it/7339>\
**Category:** Sovol SV06 Plus ACE\
**Tags:** firmware\
**Created:** [March 27, 2025, 3:43pm UTC](https://forum.sovol3d.com/t/what-firmware-should-i-be-using-for-the-sv06-ace-plus-and-where-should-i-be-getting-it/7339 "2025-03-27T15:43:00Z")\
**Showing post:** 2
**Author:** ![Oliver](https://yyz2.discourse-cdn.com/flex030/user_avatar/forum.sovol3d.com/oliver/32/2593_2.png) [@Oliver](https://forum.sovol3d.com/u/Oliver)\
**Post date:** [March 27, 2025, 6:59pm UTC](https://forum.sovol3d.com/t/what-firmware-should-i-be-using-for-the-sv06-ace-plus-and-where-should-i-be-getting-it/7339/2 "2025-03-27T18:59:22Z")
I understand the question to mean that there’s a problem with the firmware? I’m using the Sovol firmware, which I updated via the display menu. How I resolved the error message is described in the other topic.
> [@Good printer](https://forum.sovol3d.com/t/good-printer/7014/4):
> Can everyone find the solutions to the problems in the SV06 ACE area or do we need an overview? Only the “Deprecated Klipper Option” needs a small adjustment. The value changes to 0.67 because the “max\_accel” is 15,000. The entry here must be “minimum\_cruise\_ratio: 0.67”. The Orca profiles have already been revised by Orca and should appear with version 2.3.0. The error messages for arc mode can be eliminated with an entry in the printer.cfg. [gcode\_arcs] resolution: 0.25 # An arc will be …
_[View the full topic](https://forum.sovol3d.com/t/what-firmware-should-i-be-using-for-the-sv06-ace-plus-and-where-should-i-be-getting-it/7339)._
