Visible layer lines? Inconsistent extrusion?
Lately, printing on my SV08 has revealed some very visible inconsistent layer lines for lack of a better description or words.
See attached images. The cylinders are printed in vase mode.
What I have done:
Recalibrated filament for testing, recalculated the rotation distance, disassembled the pillars to make sure there’s nothing stuck, changed the extruder gears (from a spare), switched the nozzle hotend assembly, ran all the preset calubrations like belt test etc, went back to stock firmware, remove the entire toolhead and reseat it. I also have the Valerie extrusion fix in place.
Thus my previous post about sv08 lubrication.
Any assistance will be highly appreciated.
Hello
Look like inconsistent extrusion, you check the filamentroute? Some resistance somewhere can give you this results. And you sure the belt tension of the Z is ok?
What filament u use and what temp you print?
Already tried with low speed?
The attached images are using Geeetech Matte PLA printed at 215 degrees. The outer speed is 80mm/s. The acceleration are down to 8000.
How would I confirm the Z belt tension?
You need to measure the frequentie, you can do it with a app on your phone.
There are some tools also, i have one of BIQU
@Walimang
Worth taking a look at this article as well, If you find the gear pin is loose, use the model recommended by @Lion in the same article. Sovol Zero – under-extrusion caused by worn extruder gear (Solution update - loose pin)? Need advice on replacement - #2 by cardoc
Chears,
-Mike
Thanks Mike, I forgot to Bookmark that thread & couldn’t find it.
Thank you @MikeHides . I already have that fix in place.
I have one of those tools too, though a generic one.
I could not find the correct values in mm, do you have them for the sv08?
