Hi all, I’ve had my SV08 since the summer and it’s been great for printing models other people designed. Now I’ve been given a commission I have no idea how to do.
My 7-year-old drew a “dragon cat” (cat body, little wings, very long tail) and wants it as a figure for her shelf. All I have is her colored-pencil drawing, front view only. Target size around 10 cm tall.
What I’m wondering:
How do you get from a single flat drawing to a 3D shape? Extruding the outline in CAD would make it look like a cookie cutter. Do people sculpt this kind of thing from scratch, or is there a way to get a rough 3D version first and fix it up?
The wings and tail are thin. Would you print it in parts and glue, or in one go with tree supports?
With the stock 0.4 nozzle, what layer height and speed would you use for a small figure like this so the face doesn’t turn into a blob? I usually run the default profile.
Since the SV08 is single color I’m planning to paint it with her afterwards, which she’s more excited about anyway.
Example of a Viking figure I did for a Game board, used a photo I found online and AI filled in the back. Having more angles of various similar type figures helps influence the guessed 3D fill quality.
As Mike said there are MANY AI picture to 3D solid platforms. I’ve played with 4 or 5 on their demo/free plans. I found that Hyper3D worked best for me. They allow you to add a text prompt to refine (within limits) how the image is interpreted.
That would prevent AI from corrupting her art. Simply a greyscale image converted to thickness. Technically 3D but the the image is aspect ratio is preserved.
