# Tilted bed advice
**URL:** https://forum.sovol3d.com/t/tilted-bed-advice/6697
**Category:** Sovol SV06 ACE
**Tags:** bed-leveling, uneven-bed, advice
**Created:** [January 25, 2025, 4:04pm UTC](https://forum.sovol3d.com/t/tilted-bed-advice/6697 "2025-01-25T16:04:50Z")
**Posts on this page:** 1
**Showing post:** 3
### Author: ![minaskar](https://yyz2.discourse-cdn.com/flex030/user_avatar/forum.sovol3d.com/minaskar/32/2841_2.png) [@minaskar](https://forum.sovol3d.com/u/minaskar)
#### Post date: [January 25, 2025, 4:23pm UTC](https://forum.sovol3d.com/t/tilted-bed-advice/6697/3 "2025-01-25T16:23:20Z")
For small objects this shouldn’t matter. But for larger ones you’ll experience bad first layers.
This is a very common “issue” with most modern printers. See [here](https://forum.sovol3d.com/t/warped-bed-question/6637/16) how I resolved it in my case in under 30 minutes. Ideally you want to get the min-max range below 0.2 mm so that the automatic bed leveling can compensate for the rest.
_[View the full topic](https://forum.sovol3d.com/t/tilted-bed-advice/6697)._
