The report describes how two Sovol SV06 mainboards failed with low-resistance defects, how the author diagnosed the problem step by step, and how the printer now runs stably with a BTT SKR Mini E3 V3.0, isolated USB 5 V and a permanently cooled mainboard.
Sovol SV06: Two Mainboard Failures – Troubleshooting, Measurements and Final Rebuild
Perhaps this report of my experience will help other SV06 owners with similar symptoms. My printer had previously been running stably with Klipper/Mainsail on a Raspberry Pi 4. Then a troubleshooting odyssey began that ended up involving two original Sovol mainboards, the ribbon cable, the hotend and the heated bed.
Symptoms
At first, Klipper reported heater_bed no longer approaching target while heating the bed. Despite full heater power, the bed stayed at around 90–93 °C instead of 100 °C. Shortly afterwards, Got EOF when reading from device and Lost communication with MCU 'mcu' appeared as well. Since communication dropouts also occurred with the printer cold, the heated bed alone was not a sufficient explanation.
I tested several USB cables and Raspberry Pi ports. Other USB devices worked fine, while the defective board visibly put a strain on the USB power supply.
The key measurement
On the failed Sovol mainboards, the resistance between the logic supply and GND was only about 0.4–0.5 Ω. A brand-new original Sovol board, by comparison, showed roughly 1.190 kΩ. That made it clear that the boards themselves were electrically damaged.
The tricky part: the replacement board worked at first
A new original Sovol mainboard was flashed, checked and installed. Voltages and resistances looked normal, the USB connection worked again, and a long PETG print ran for several hours without errors. We were convinced the repair was complete.
Later, however, this new board failed as well. That was the turning point: simply connecting yet another board in full and hoping for the best was no longer an option.
What was replaced?
  • 2 original Sovol mainboards
  • the complete ribbon cable
  • the complete hotend, including heater cartridge and thermistor
  • the complete heated bed, including heater and thermistor
  • later, as the final board: BIGTREETECH SKR Mini E3 V3.0
In addition, the following were implemented permanently: a USB 5 V isolation and an 80 × 80 mm mainboard fan running continuously.
Heated bed measurement log
Measurement Result
Old heated bed – heater 3.0 Ω
Old heated bed – thermistor 103.6 kΩ
New heated bed – heater 2.9 Ω
New heated bed – thermistor 102.3 kΩ
Heater wires to aluminum plate OL
Heater wires to thermistor wires OL
Both beds appeared electrically fine in the static measurement. The old heated bed was replaced completely anyway. A connection between the heated bed and the board defects could therefore not be proven.
Change of strategy: connecting components one at a time
After the second board failure, the new board was first measured and tested without any peripherals. Then the stepper motors, sensors, hotend, fans, Z probe, filament sensor, and the heated bed thermistor and heater were reconnected one by one in a controlled manner.
The principle: power off → connect one component → measure → power on and test → power off again → next component.
Final board: BTT SKR Mini E3 V3.0
Before any peripherals were connected, the brand-new SKR Mini E3 V3.0 showed about 186 kΩ from 5 V to GND and 1.876 kΩ from 3.3 V to GND. With everything fully connected, the readings were about 1.827 kΩ and 1.534 kΩ, respectively. A hard short circuit like the one on the failed Sovol boards could not be reproduced.
Two additional protective measures
  1. USB 5 V isolation: An adapter interrupts the 5 V line between the Raspberry Pi and the mainboard. I measured approx. 5.32 V on the Raspberry Pi side and 0 V on the board side. The mainboard is therefore powered exclusively by the printer’s 24 V supply.
  2. Permanent mainboard cooling: An 80 × 80 mm fan was integrated into the enclosure and runs continuously. This makes the board cooling independent of the part cooling fan, which is especially relevant when printing ABS/ASA in an enclosure.
Conclusion
Despite extensive troubleshooting, the original root cause could not be determined with certainty. What is proven, however, are the low-resistance defects on several Sovol mainboards. The heated bed, hotend and ribbon cable were replaced, and afterwards no comparable external short circuit could be reproduced on the complete peripherals.
My most important takeaway: a replaced part is not yet a completed diagnosis. If a new board fails again after an apparently successful repair, I would no longer connect everything at once.
My approach today would be: test the board on its own → check the power supply → isolate USB 5 V → connect the loads one at a time → measure and test after every step.
The SV06 is now running stably again with Klipper, a BTT SKR Mini E3 V3.0, an isolated USB 5 V line and a permanently cooled mainboard.
