# SV08 Max layer shift on test benchy
**URL:** <https://forum.sovol3d.com/t/sv08-max-layer-shift-on-test-benchy/8741>\
**Category:** Sovol SV08 MAX\
**Created:** [September 16, 2025, 1:54am UTC](https://forum.sovol3d.com/t/sv08-max-layer-shift-on-test-benchy/8741 "2025-09-16T01:54:13Z")\
**Showing post:** 5
**Author:** ![sovol3d](https://yyz2.discourse-cdn.com/flex030/user_avatar/forum.sovol3d.com/sovol3d/32/9_2.png) [@sovol3d](https://forum.sovol3d.com/u/sovol3d)\
**Post date:** [September 17, 2025, 1:26am UTC](https://forum.sovol3d.com/t/sv08-max-layer-shift-on-test-benchy/8741/5 "2025-09-17T01:26:43Z")
Hi. You can refer to the Sv08 procedure. The only difference is the gantry calibration method. The SV08 verifies that there are no gaps between the frames at the rear, while the SV08 Max verifies from the front. A video tutorial on belt adjustment for the SV08 Max is currently in development and will be updated soon. It is recommended that the A and B axis belt tension be calibrated at a target of 140Hz. Measure 150mm at each of the front and rear positions for calibration, repeating 2-3 times.
Please check the security type of the router. It can only be WPA2 and is not compatible with WPA3.
 ![image](https://canada1.discourse-cdn.com/flex030/uploads/sovolforum/original/2X/6/6dbfce3114846515fd11fd83ae1c5d2442babc70.jpeg)
_[View the full topic](https://forum.sovol3d.com/t/sv08-max-layer-shift-on-test-benchy/8741)._
