# SV08 connect Smart Filament Sensor
**URL:** <https://forum.sovol3d.com/t/sv08-connect-smart-filament-sensor/9949>\
**Category:** Sovol SV08\
**Created:** [May 1, 2026, 3:43pm UTC](https://forum.sovol3d.com/t/sv08-connect-smart-filament-sensor/9949 "2026-05-01T15:43:47Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Turbojoke](https://avatars.discourse-cdn.com/v4/letter/t/54ee81/32.png) [@Turbojoke](https://forum.sovol3d.com/u/Turbojoke)\
**Post date:** [May 1, 2026, 3:43pm UTC](https://forum.sovol3d.com/t/sv08-connect-smart-filament-sensor/9949/1 "2026-05-01T15:43:47Z")
</div>
Hello everyone!
I’m trying to install a Smart BTT Sensor on my Sovol SV08 printer. The sensor has 3 pins: S, V, G. It’s an optical endstop with a wheel that moves along with the filament during printing. If the wheel stops moving, it means there’s a clog, and the printer should pause for cleaning.
I connected this sensor instead of the standard `filament_switch_sensor filament_sensor`.
Here is the code I’m using:
> #[filament\_switch\_sensor filament\_sensor]
> #pause\_on\_runout: True
> #event\_delay: 3.0
> #pause\_delay: 0.5
> #switch\_pin: PE9
> [filament\_motion\_sensor BTT\_Smart\_Filament\_Sensor]
> switch\_pin: PE9
> detection\_length: 7.0
> extruder: extruder
> event\_delay: 3.0
> pause\_delay: 0.5
> runout\_gcode:
> #PAUSE # [pause\_resume] is required in printer.cfg
> M117 Filament encoder runout
> SET\_IDLE\_TIMEOUT TIMEOUT=600000
> insert\_gcode:
> M117 Filament encoder inserted
When I start a print, an error appears in the console and the printer stops with an error.
The error message is:
> 18:10
> Error evaluating ‘gcode\_macro CANCEL\_PRINT:gcode’: jinja2.exceptions.UndefinedError: ‘extras.gcode\_macro.GetStatusWrapper object’ has no attribute ‘filament\_switch\_sensor filament\_sensor’
> 18:10
> Error evaluating ‘gcode\_macro START\_PRINT:gcode’: jinja2.exceptions.UndefinedError: ‘extras.gcode\_macro.GetStatusWrapper object’ has no attribute ‘filament\_switch\_sensor filament\_sensor’
I think the issue is caused by some kind of macro conflict, but I don’t have enough experience to fix it.
Could someone help me with this?
 ![image](https://canada1.discourse-cdn.com/flex030/uploads/sovolforum/original/2X/0/037d1d3d1ddfef95c4eee9178351ef1d3f9a4193.jpeg)
**Post date:** [May 1, 2026, 4:47pm UTC](https://forum.sovol3d.com/t/sv08-connect-smart-filament-sensor/9949/2 "2026-05-01T16:47:49Z")
</div>
Alright, I figured it out. This solution might not be the most correct one, but it works.
Here’s what to do:
> event\_delay: 3.0
> pause\_delay: 0.5
> switch\_pin: extra\_mcu:PA9
> [filament\_motion\_sensor encoder\_sensor]
> switch\_pin: PE9
> extruder: extruder
> event\_delay: 3.0
> pause\_delay: 0.5
> runout\_gcode:
> insert\_gcode:
Now the printer thinks that `extra_mcu:PA9` always has filament inserted, and it only processes pause/runout errors from `PE9`.
Make sure to turn off the switch shown in the screenshot.
 ![image](https://canada1.discourse-cdn.com/flex030/uploads/sovolforum/original/2X/9/9ebcf75e4cbacacfbd2382663bd86b26b69d0394.png)
**Author:** ![cardoc](https://avatars.discourse-cdn.com/v4/letter/c/ec9cab/32.png) [@cardoc](https://forum.sovol3d.com/u/cardoc)\
**Post date:** [May 1, 2026, 6:06pm UTC](https://forum.sovol3d.com/t/sv08-connect-smart-filament-sensor/9949/3 "2026-05-01T18:06:08Z")
</div>
Welcome to the forum.
Your issue is the start\_print macro looks for the filament sensor by the name you commented out.
```auto
[gcode_macro START_PRINT]
description:
variable_state: 'Prepare'
variable_record_extruder_temp:0
variable_max_record_extruder_temp:0
gcode:
    {% set mesh_name = "default" %}
    {% set mesh_calibrate_temp = printer['gcode_macro _global_var'].bed_mesh_calibrate_target_temp|int %}
    {% set extruder_target_temp = printer.extruder.target|int %}
    {% set bed_targer_temp = printer.heater_bed.target|int %}
    M400
    CLEAR_PAUSE
    G90
    {% if state == 'Prepare' %}
        {action_respond_info("Prepare!")}
        {% if printer.toolhead.homed_axes|lower != "xyz" %}
            G28
        {% endif %}
        {% if printer**['filament_switch_sensor filament_sensor']**.enable == True and
              printer**['filament_switch_sensor filament_sensor'].**filament_detected != True
            M117 No filament!!!
            {action_respond_info("Please Insert filament in Sensor!")}
            CANCEL_PRINT
        {% endif %}
        {action_respond_info("Check Heating!")}
        M140 S{bed_targer_temp}
        M104 S{extruder_target_temp}
        {% if printer.heater_bed.temperature < bed_targer_temp %}
            M117 Bed heating...
            {action_respond_info("Bed heating...")}
            M190 S{bed_targer_temp}
        {% endif %}
        {% if printer.extruder.temperature < extruder_target_temp %}
            M117 Nozzle heating...
            {action_respond_info("Nozzle heating...")}
            M109 S{extruder_target_temp}
        {% endif %}
        {% if printer.quad_gantry_level.applied|lower != 'true' %}
            QUAD_GANTRY_LEVEL
        {% endif %}
        BED_MESH_CALIBRATE ADAPTIVE=1
        SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=state VALUE='"Start"'
        UPDATE_DELAYED_GCODE ID=_print_start_wait DURATION=0.5
    {% elif state == 'Start' %}
        M117 Printing now!!!
        {action_respond_info("Start!")}
    {% endif %}
Note under Klipper a [[filament\_switch\_sensor]](https://www.klipper3d.org/Config_Reference.html?h=runout#filament_switch_sensor)
And a [[filament\_motion\_sensor]](https://www.klipper3d.org/Config_Reference.html?h=runout#filament_motion_sensor)
Are not the same thing.
Configure the new sensor correctly. Uncomment the [‘filament\_switch\_sensor filament\_sensor’] section and change the pin reference to an unused pin.
Add this near the top of your configuration.
```auto
[delayed_gcode startup_disable_filament_sensor]
initial_duration: 0.5
gcode:
  SET_FILAMENT_SENSOR SENSOR=filament_sensor ENABLE=0
OR search every macro for [‘filament\_switch\_sensor filament\_sensor’] and edit it. Delete the check or point it at the new sensor. AFAIK Klipper sets the senor true at initialization. That would allow a print to start with no filament loaded but would stop when the sensor failed to toggle after 7mm of extruder moves.
**Post date:** [May 1, 2026, 6:07pm UTC](https://forum.sovol3d.com/t/sv08-connect-smart-filament-sensor/9949/4 "2026-05-01T18:07:06Z")
</div>
Oops, cross posted. Glad you got it sorted.
