# SV06 Overhangs problem
**URL:** <https://forum.sovol3d.com/t/sv06-overhangs-problem/1403>\
**Category:** Sovol SV06 Fully Open Source 3D Printer\
**Created:** [January 23, 2023, 6:51pm UTC](https://forum.sovol3d.com/t/sv06-overhangs-problem/1403 "2023-01-23T18:51:21Z")\
**Showing post:** 4
**Author:** ![kord2003](https://avatars.discourse-cdn.com/v4/letter/k/59ef9b/32.png) [@kord2003](https://forum.sovol3d.com/u/kord2003)\
**Post date:** [January 24, 2023, 2:28pm UTC](https://forum.sovol3d.com/t/sv06-overhangs-problem/1403/4 "2023-01-24T14:28:56Z")
Stock part cooling fan can be adjusted to improve cooling performance.
Please check this thread for solution.
> [@SV06 - Overhangs curling upwards, making nozzle knock over the print](https://forum.sovol3d.com/t/sv06-overhangs-curling-upwards-making-nozzle-knock-over-the-print/1335/26):
> @sv06 @ImTheLiquor I think I found what causes the bad part cooling. 1. First of all, part cooling fan facing down is a terrible design decision. It sucks hot air from the heated bed, resulting in less efficient part cooling. 2. 4010 fan isn’t powerful enough. 3. Inefficient part cooling shroud which blows from the front and a bit from the left, providing less cooling to the back and to the right side of the print. Some other printers have more advanced shrouds which blow from the opposite s…
_[View the full topic](https://forum.sovol3d.com/t/sv06-overhangs-problem/1403)._
