# SV06 Mainboard brick after updating Sovol Firmware
**URL:** <https://forum.sovol3d.com/t/sv06-mainboard-brick-after-updating-sovol-firmware/862>\
**Category:** Sovol SV06 Fully Open Source 3D Printer\
**Tags:** firmware\
**Created:** [November 24, 2022, 6:20pm UTC](https://forum.sovol3d.com/t/sv06-mainboard-brick-after-updating-sovol-firmware/862 "2022-11-24T18:20:05Z")\
**Showing post:** 68
**Author:** ![v1ncen7](https://avatars.discourse-cdn.com/v4/letter/v/c0e974/32.png) [@v1ncen7](https://forum.sovol3d.com/u/v1ncen7)\
**Post date:** [March 16, 2023, 10:51pm UTC](https://forum.sovol3d.com/t/sv06-mainboard-brick-after-updating-sovol-firmware/862/68 "2023-03-16T22:51:10Z")
@sovol3d I have the same issue and I am unable to fix it despite numerous attempts… I received the printer yesterday, could print a benchy, then followed the steps to update the firmware. Only blue screen lights up now.
I sent you an email with the details to [info@sovol3d.com](mailto:info@sovol3d.com) along with the order number.
Let me know if any other troubleshooting steps…
[UPDATE]
I managed to fix it today. I spent a lot of time in forums, with some mentioning non sensical things like making the firmware file executable, etc.
In case this helps someone:
- Use a small 8GB SD card
- Format the card with FAT32 and make sure you set the sector size to 4096 bytes (or ‘4K’) (-\>This is critical, many cards come formatted with 512b sector size)
- copy only one firmware (bin file) and rename it with a short simple name that was not used before for flashing.
I tried with many sd cards, formatting them from Mac os, Ubuntu and Windows without luck until I found about the sector size requirement. Then it worked right away.
_[View the full topic](https://forum.sovol3d.com/t/sv06-mainboard-brick-after-updating-sovol-firmware/862)._
