or print a filament sensor yourself with an end-stop-swtich
and connect it to x-y-z stop ?
if there is no more filament, it cannot print air for hours…
but software ???
the SV06 has no X, and Y stop switches. So the connections are still free. Maybe print out a template for a filament sensor and insert a microswitch. Then connect GND and x-Stop connection.
The other must be set in the software.
But I’m not there yet.
Or connect the filament sensor to Octoprint. GND and IO pin
Then the software is easier
#define FILAMENT_RUNOUT_SENSOR #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500. #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each.
#define FIL_RUNOUT_STATE LOW //HIGH // Pin state indicating that filament is NOT present.
// umgekehrte Logik. Der PIN wird über 10k gegen + 3.3 V gehalten
// wenn der Sensor fehlt ist der Schalter offen
// schaltet der gegen GND dann fehlt das Filament → M600 Filament Change
// reverse logic. The PIN is held against +3.3V over 10k
// if the sensor is missing the switch is open
// switches to GND then the filament is missing → M600 Filament Change
// Jens #define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins.
