Rapid Burner / Dragon Burner for SV08
Hi, everyone. Thanks for reading :slight_smile:
I’m looking to upgrade my toolhead to the SV08 and wanted to set up a Rapid Burner or a Dragon Burner—I’ve seen several images of them online. But for some reason, I can’t find “the adapter” anywhere in the official Rapid Burner or Dragon Burner projects—they’re designed for Voron, which has a different X-rail that doesn’t fit. I was looking for an adapter that would let me mount it on my SV08, but I can’t find any CAD or STL files that would allow that. Does anyone know where I can find one?
Welcome to the form.
The CAD (step format) files for the SV08 are at:
What probe do you intend on using? You might want to explore “mainline” options to get off Sovol’s fork and enable more probe options.
Hi Cardoc.
Thanks for your reply.
I’m not trying to set up a single specific model. I have a Rapid UHF V1, a Sherpa Mini and an EBB36 from an old build. I’m planning to mount them on this machine using the Rapid Burner.
If possible, I also have an Eddy and a Cartographer.
The thing is, as far as I understand, the Rapid Burner MGN12H mounting doesn’t match the SOVOL SV08 in terms of belt alignment and spacing. I understand this causes problems when using it and leads to premature wear of the belts. That’s why I was looking for an ‘adapter’ that would allow me to fit it correctly.
