# Power connector overfused
**URL:** <https://forum.sovol3d.com/t/power-connector-overfused/9008>\
**Category:** Sovol SV08 MAX\
**Created:** [November 13, 2025, 8:24pm UTC](https://forum.sovol3d.com/t/power-connector-overfused/9008 "2025-11-13T20:24:36Z")\
**Showing post:** 13
**Author:** ![torch](https://avatars.discourse-cdn.com/v4/letter/t/8e7dd6/32.png) [@torch](https://forum.sovol3d.com/u/torch)\
**Post date:** [November 23, 2025, 11:50pm UTC](https://forum.sovol3d.com/t/power-connector-overfused/9008/13 "2025-11-23T23:50:28Z")
I finally had the opportunity to print a number of parts in ASA (similar temps to ABS) the past two days.
I have had complete success and no blown 10A fuses. The draw is greatest during the initial warm-up phase, bumping up hard against 10A (@ 110VAC today) for about 15 minutes until the bed temp is reached. However, maintaining the bed temp (inside the enclosure) for the ensuing heat soak only draws between 6 and 7 amps with Mainsail reporting 40 to 60% duty cycle.
By the time it’s actually printing at speed (300mm/s), the bed heater duty cycle is down to 20 to 40% and the current draw drops further. The highest I observed was 6.25A – although it’s entirely possible that could be exceeded for a moment at some point.
So, @sovol3d: Cheap fix. Don’t risk violating electrical safety certification; stop overfusing. Ship the 125V version with 10A fuses!
_[View the full topic](https://forum.sovol3d.com/t/power-connector-overfused/9008)._
