Other filament and process profile?
Anyone has filament profiles for Prusament and Ouverture PETG ?
Also looking for other process than just 0.2mm layer with 0.4mm nozzle, will like to have more options like ‘draft’, ‘speed’, ‘fine’ …
Tell Orca its a Voron 2.4 (modify/save Voron 2.4 350 profiles), (use the dev channel, build from git if you can, it crashes less) increase bed to 500x500, height to 400 or 500 (400 if you have lid on) you will have all the profiles you want. Max is essentially a big Voron 2.4 with a high flow hot end. Do fix the config with the realistic accels /speeds etc as shown in several threads, things will work/look much better/more reliable. You can load the Max bed .stl and texture available online.
