The pack from my Expanded SuperSlicer & PrusaSlicer profiles thread has been updated. I have finally included OrcaSlicer, and it is currently just on GitHub (will update Printables soon too).
Klipper macro pack
Easy to install, just one consolidated file for either the 1.3.x or 1.4.x firmware branches. What it adds:
PID exhaust fan chamber control
The original watermark behavior is what got me started here, and its development is documented at PID Controlled Exhaust Fan (Quiet!). Same behavior today, with bugfixes and more use of temporary variable instead of writing to disk.
Bed boost
Since the chamber temperature sensor is whacked fiasco, I automated the community practice of instead using the nozzle temp for the pre-heat. Since that’s only valid with a cold hot end, the macro gates that validity, and uses the part cooling fan to get there, so bed boost works both starting cold and with back-to-back prints.
Since the part fan has to be running anyway, I also decided to find at what Z height would that would unleash the most out of our ridiculously overpowered beds, and figure out the adaptive timing to figure out how much additional bed heating for how long, while overlapping with nozzle heating & cleaning to minimize time and ooze. It learns based on your printer.
Controlled Cooldown
Warping is a problem, and the Zero’s well regarded for high temperature use, so I wanted to also better manage the cooldown. At the end of the print, settles for a few minutes (triggered by nozzle dropping down to bed temp), and then begins a linear ramp of the bed temp, facilitated by the gentler exhaust fan initially, and later by the rear aux curtain fan.
Below about 40 °C the plate can’t fall much faster than 2 °C/min even with both fans flat out, which is where the default rate comes from. Overall ramp rate is easily adjusted to be slower for more demanding materials, or faster (& non-linear) if that’s your preference.
The cooldown weights the two fans by how hard each one actually cools the plate. Measured on my Zero, the curtain fan pulls 1.3 to 3.4 times the heat out of the plate that the exhaust does, depending on bed height, which is handled by the initial latching of the curtain fan and simultaneously reducing the exhaust so the transition is equal cooling, and from there it becomes a blended throttle arrangement.
Other features
- Square corner velocity is sent per tier
- improved silicone nozzle brushing pattern
- Less nozzle ooze in the first place (better retracts, tighter timing, adaptive temperature, warmer wipe)
- KAMP-inspired purge, using slicer emitted filament material velocities, placed in a circular ring (when area is available) near the camera for easy inspection
- Optional Spoolman check of material and remaining filament before heating
- Filaments carry their nominal shrinkage values (ought to be standard practice)
- exhaust & curtain fan RPM corrections, improved PWM and kick for lower & adaptive minimum speeds
Precision mode (& generalized automatic stepper changes)
Inspired by the Motor tuning thread and related Discord conversations, I also setup slicer printer profile hooks to emit changes to the klipper stepper motor config. Hence SV Zero Precision, for slow, quiet, fine-detail prints on the stock 0.4 and smaller nozzles: five tiers from 0.04 to 0.12 mm, 64 microsteps with interpolation off, reduced current, and the slower velocities and accelerations you would expect. Mode switching is automatic - if klipper is in the wrong mode, it’ll refuse, swap files, restart, and resume the job with the correct settings automatically.
I have done test prints with this mode, and am happy with the results, but I’m sure there are more tuning improvements to be had.
The big result is the platform to easily switch configurations - could also be used in the other direction for more aggressive settings, like the 48V speedboaters out there.
Downloads
| Slicer | Install |
| OrcaSlicer | Copy profiles/SVZero.json and profiles/SVZero/ together into Orca’s system/ directory |
| PrusaSlicer | Import SVZero_PrusaSlicer.ini |
| SuperSlicer | Import SVZero_SuperSlicer.ini |
Each ZIP includes INSTALL.md and the optional Klipper macro pack. One source generates the profiles for all three slicers, so they ask for the same speeds and accelerations.
