Need help with fine tuning
I am trying to print a big case and I have used this cutout to test my settings. Can somebody tell me which settings could improve the wall quality?
The easiest fix for print quality is slowing print speed. Adding a tiny bit of fuzzy skin in the slicer can also go a long way to hide layer lines and other print defects. Check and adjust belt tensions. Run input shaping and limit accelerations. Doing calibration tests for temperature, flow rate, pressure advance, retraction, etc. are more work but are helpful to achieve better print quality without sacrificing as much speed.
Also make sure that these 2 boxes are checked.
Thanks for the detailed tips! I’ll try slowing down the print speed first and check the belt tension. The calibration tests also sound useful for improving print quality without losing too much speed.
Good tips above. Also
This allows the slicer to do a thin internal wall to hold your model dimension. Another method is to edit the model and set the vertical wall thickness to an exact multiple of your wall thickness.
I use fuzzy skin a lot. Downside is slicing is slower, g-code files are much larger, and can lead to “timer too close” if you print too fast.
Flow rate and pressure advance need to be spot on. For ultimate quality they need to be verified for each filament, even different colors from the same supplier.
@HandyDoodads @cardoc
Thanks for you tips and tricks.
First, I checked the belt tension. It really needed tightening.
Fuzzy skin also looks much better.
The print speed is already slowed down
What option can i use to improve the overhang quality? faster, slower or lower flow rate?
When approaching an overhang, it is always best to reduce your speed.
As for flow rate, the best solution is to perform a calibration.
The overhang (lower arrow) and bridge (upper 2) settings are related but treated separately in the slicer.
First run a temperature tower. You need to find the lowest temperature that still gives good layer adhesion. The cooler strand sags less and solidifies faster.
Next increase the part cooling. The Max has 2 part fans. I read someplace that 1 user felt using both at once resulted in LESS cooling. They claimed air speed was compromised by the fans blowing against each other. YMMV.
Looking much better.
Another good thing to do is look very carefully in the slicer preview at every ugly spot in your print and try the various options to show seams, travel and retractions which are common points of trouble to try and identify what might be giving you trouble. Also go through the various modes showing print speed, flow and fan speed and you might notice trouble where there are abrupt transitions. It might indicate a need to set a fan spin up time adjustment or increase the minimum fan speed.
To improve overhangs try slowing print speed, increasing cooling, decreasing layer height or using variable layer height. Sometimes wall order or extrusion widths can make a difference. Changing part orientation can help in some cases.
