Mensaje
Hello everyone. I urgently need help recovering my Sovol Zero. Unfortunately, after following a troubleshooting procedure, the printer is now stuck and I can no longer access the system.
Here is exactly what happened:
Original problem: My Sovol Zero was running firmware 1.4.7. I replaced only the toolhead PCB. The original mainboard, original eMMC and original Sovol Eddy sensor are still installed.
After replacing the toolhead PCB, Klipper reported an MCU protocol mismatch between the host and the toolhead MCU.
Troubleshooting procedure: I was advised to create a temporary printer.cfg configuration to start Klipper using only the mainboard, disconnecting the toolhead MCU from the configuration temporarily.
The original configuration was preserved as printer.cfg.orig, and the temporary configuration was saved separately as printer.cfg.temporal.
The temporary configuration included:
[mcu] with CAN UUID 0d1445047cdd
[printer] with kinematics: none, max_velocity: 1 and max_accel: 1
Shell command and macro sections intended to run the toolhead firmware update script.
However, my installation does not recognize RUN_SHELL_COMMAND.
What went wrong: After activating the temporary configuration, Klipper reported this error:
Option ‘max_velocity’ in section ‘printer’ must be specified.
After attempting to address that configuration error, the printer stopped booting correctly.
Current situation:
The printer’s screen remains permanently stuck on System Booting.
I cannot access Mainsail.
I cannot access the printer through its previous IP address.
SSH access is unavailable because the credentials are rejected.
I cannot access the configuration files through the web interface.
The original mainboard and eMMC have not been physically replaced or intentionally reflashed.
I urgently need help with the following:
How can I recover the original operating system and configuration?
Is it possible to access the eMMC externally and restore the original printer.cfg without reinstalling the entire system?
Can I recover the original eMMC contents without losing the printer’s calibration, settings and other files?
Is there an official recovery procedure or original 1.4.7 system image for the Sovol Zero?
I have spent several weeks trying to solve the original toolhead firmware compatibility problem. Now I need to recover the printer first.
I would really appreciate detailed, step-by-step guidance from someone who has experience recovering a Sovol Zero in this condition.
Thank you very much for any help.
