I was running a 19 hour long print and the printer suddenly stopped and asked to restart firmware or “something else” that I can’t recall. I SSH’s into the machine and was able to upload the logs directly to a website that analyzed them. The problem is that the way it parses the data it’s very hard for me to see relevant data.
I did not accidentally click Emergency Stop
Power Loss Recovery Lag - it failed to save the print and I’d like to turn it off if it helps with CPU load, it’s all or nothing with the prints for me.
EMI with the toolhead, no idea how to check for this but AI is saying check it - any ideas??
Fan/Thermal issues - I highly suspect this, just need to know it is the problem or not
Click this to go to the results:
I modified the cooling fan for the mainboard, is the mainboard now overheating?
I modified the filament auxiliary feeder to not make as much noise when feeding, is this hanging up the tool head now?
Is there a “better” log parser?
I saw a 79.6C for the host (which I think means the main motherboard) and I know things happen at 80C (I think, I can’t find where that limit is programmed at), did this limit shut me down?
I see a blocking IO Error (Errno 11), did this occur due to over heating?
Would NOT running the 0-3 FPS webcam help things? If so, how can I view the machine without taxing the motherboard?
Is there an moonraker-obico log on your machine? It SHOULD admit it if it sent an E-Stop.
I’ve never used Obico but Sovol ships it preinstalled on all their machines. They even autostart the linux service even if you never sign up for Obico
IMO either there is $ and/or user data flowing from Obico > Sovol
If you don’t use it KIAUH will uninstall it. Make sure the service got removed (ask Claud).
Were you in front of your PC when it stopped unexpectedly? Mainsail has a setting to confirm before sending an E-stop… Some think it defeats the purpose of an EMERGENCY stop
