Haha yes not even close to there, here in Belgium a lot of rain ![]()
You know, I live in France.
Right now, it’s cold, the sky is overcast, and it’s raining a little.
I don’t like it.
Today i swap soms parts/sparte parts , do some cable/tube work, and clean up the tubes and valves of the T Rex Head
Because i overheated my previous lgx pro with pushibg the run current to 8.5a
, i ordered some spare parts and also 2 Lgx Lite Pro for the 62 and 63
I test and calibrate a lot and for me is the best setup:
(Also the pictures and movie with this settings)
Directly extrusion test:
Run current not 0.85 but 0.65 (the max by Bondtech)
90mm3/s passed
95mm3/s Extruder motor starts stalling
Sustained flow test 30min at 80mm3/s
Rotation Distance 3.920
Stabil settings and setup:
Hotend: Rapido 2 UHF
Nozzle: 1.0mm CHT Bimetal Volcano
Extruder: Bondtech LGX Pro Lite
Tempsensor: PT1000
Pull Up Resistor: 10.000
Filament: Professional Lab PETG
Pressure Advance: 0,02
Flowratio: 0,9003
Max Volumetric speed 80mm3/s
Outer wall speed: 155mm/s
Layer height: 0.5mm
Line Width 1.2mm
Max Velocity: 700
Max Accel: 20.000
Probe: 61&63 Eddy Duo - 62 Beacon Rev H
Partcooling: Custom fanduct with Elegoo 5020
Heatsink cooling: Push Pull Duo 4020 LDO/Sunon fans
Auxilery Extruder: Mellow LLL Plus
Motion & Runout sensor: BTT Smar Filament Sensor V2.0
I know its not modding my sovol but modding a Logo ![]()
I will show you how i bring logo’s a life. Everything is printed @ my Sovols. This logo has gears/wheels and i let them spin arount with a LDO stepper and timing belts. All the pully’s for the shaft i designed and printed.
2nd movement is the sword, with a actuator the sword goes in and out.
3th of course leds, with ws2812b
All the electronic i will assemble in self designed electro boxes.
I use mosfets, H bridge drivers, buck convertor, ESP32 , stepper drivers, meanwell power supply…
So i will build a small control panel with a lot of 3D printer parts ![]()
